Help JD! Need benchmark.
JD, I've been running the blue needle setup for my 2005 CRF450 w/ Dr. D full pipe and air filter screen removed. I smashed my pipe so I will be going back to stock pipe. Everything on bike is stock and I have removed the back air filter screen. I'm in AZ with temps 60 degrees - 85 degrees. Elevation between 400 - 1700 ft. What combo should I try? I'm guessing maybe Red Needle, 4th clip, 172 mj.
We received our pipe guard last night from E-Line (Kevin Hines). Installed it and fit, etc. was excellent. This is on the DR. D pipe on our 2005-CRF450. It will definitely solve the boot damage problem and will go a long way to protect the pipe from damage also. Others on TT have been looking for a pipe guard for this pipe on this bike, so thought I would pass it along. Our dealer got it for us from E-Line apparently. Our dealer is Tech-Care Suspension in Waterford, MI. (tech-care.com) Hope this helps.
