cr 80 / crf 150
I started to do the suspension swap on the 150 . The forks will work with very little work .
I have a question about the back wheel . I am going to get the rims and spokes changed to the mini moto wheels .
I would like to put the cr 80 rear wheel on the 150 . I can get the brake master cylinder on the bike .
But the back wheel axle is to short and to small for the 150 swing arm .
I would like to ask if any one has made this rear wheel change .
Thanks for the Help
Just go to a bearing place and get bearings with a bigger inside diameter and use your stock axle. My friend did that to get a cr250 hub on a cr85 axle. It worked like a charm. :cry:
