Which JD main jet in TX on an '05 CRF450? 178 or 180?
I'm just sort of rebuilding my new bike to get it ready to ride and the instructions w/ the JD jet kit are not crystal clear on this for the '05.
Of course it is a bit cold and I have removed the backfire screen.
I was hoping to get a good starting point.
Which main jet should I use? What about the needle? Which one and where should I put the clip?
Thanks.
Try the #178 or #175 main jet. It seems the '05 is favoring a slightly smaller main and richer clip position, such as red #5 or #6.
Thanks,
James
James, the instructions w/ the JD jet kit say to use the blue needle one clip position leaner when the temps are below 65 degrees. Do you still recommend that or should I use the red needle?
Yes, for colder weather I would try the blue needle in the middle clip position, keeping the fuel screw near 1 1/2 turns. This richens 0-1/4 throttle compared to the red needle. Use clip #3 if the change is too much.
Thanks,
James
