Sidi Flex Force SRS vs. Sidi Force SRS???
Anyone know what the difference is between these two?
One has screws on the bottom to replace the sole, the other is bonded to the bottom. One is a bit wider than the other also. I can't remember which is which but check out the websites that sell them and there will be a description, some sites are better than others.
The srs means Sole Replacement System. I think this is the best boot made, either one.
I've had the Sidi Flexs Force for three years now. They hold up well, and fit like a glove from day one. The flex sole allows you to "feel" your pegs better then the replaceable sole which is much stiffer. I would buy the flex. You'll never wear out the sole, unless you drag your feet a few hundred miles on ass-fault.
John
