Just remember, when a stripped bike gets you down
its going to be all that much more fun when its back together....
...my current inspiration to get working on the bike for next season
hey,at least your motor is still in the frame and in one peice.
my drz is completely apart including the motor right now.
never ending process of waiting for parts........ :cry:
Now what are you up to??
:cry::cry:
nothing i promise....... :cry:
no really,just freshening the whole thing.
i was starting to feel sorry for the crankshaft.but of course when i dissassmebled the crank the rod bearing and all was like new.
so waiting for main bearings,rod kit,rings etc.
3 years of hard use. :cry:
:cry::cry:
Burned,, I take it you do not weld your cranks.
Opinion on Yes or no? Bike Vs Quad?
i do not.quad i probably would.they are subjected to much higher loads than a bike.
it takes a 70 ton press to dissassemble a 4 stroek crank.they are pretty damn tight.
I had to weld the crank on my quad(banshee)....never had a problem with any of my bikes though.
Just out of curiosty, why did you strip it down.
Thats from a couple years ago when I did the race tech suspenion component install. The bike is in 1 piece right now.
Yea right now anyways :cry::cry:
This year on the drz involves: Changing back over to dirt from supermoto. Valve check is on the list. Custom skid plate is on the list. TT graphics on the list. More drastically... I'm going to tune in that race tech suspeion. I want to go about 30% stiffer on the high speed compression stack for the shock. She just can't soak up the big landings enough as she is. Ofcourse the front will be adjusted to match.
That's a familiar sight. Tore mine down last night, and looks identical, only yellow. I'm just off to have my shock and forks serviced. Having new springs for my weight installed. Tera-flex arrived this morning. Just about the biggest knobs I ever saw. Hard to believe it's a DOT tire.
I'm still waiting to see the stripped bike, that one had way too much stuff still on it :cry:
This is what I consider stripped:
