Bronco78..your input please...valve / shim?
Howdy, howdy...Checked clearances and shim size and found as follows;
Intake: clearance / shim size
left .005"/.127mm / 2.82mm / .111"
right .005"/.127mm / 2.80mm/.110"
Exhaust: clearance / shim size
left .011"/.279mm / 3.12mm / .124"
right .009"/.229mm / 3.15mm/.125"
I guess I'm in "spec" but would appreciate your direction especially on that right exhaust clearance. And, I'm a little confused here...to gain valve clearance I need to go down in shim size or is my head where the sun don't shine? I found shims in place that are half sized and not available from Ayers or any place else I can find so replacing with a full shim size won't be a problem? Everything looked good in the engine. Very clean which bespeaks of frequent oil changes. After having the cams out and back in I see how easy it would be to do the HotCam set-up! Your opinion also in the Wiseco piston kit? I'm forever in your debt! :cry: Thanks, Ross
drop both to a 2.75 shim.. giving you
.197 and .177.. :cry:
Leave the left as is,,,,
drop the right shim to 3.10 giving you
.279
I like mine,, 90mm 13.5:1 for now... will do a 94.5mm 13.5:1 in the near future.
