Tips for new xr owner
I recentlygot a 91 model xr 250, my first bike and love it to death. i am an ok rifer but need as much help as i can get. What kind of gear and mods do you have on your bikes? What works and what don't? Also if you have any riding tips throw them in too if you want to.
LIVE TO RIDE
RIDE TO LIVE!!!! :cry:
I used to post an XR250R faq on usenet's rec.motorcycles.dirt back in the early 90's. I dug it up on google groups - it is dated so here is a partial list that is updated to the new millenium.
1. The throttle is a push-pull throttle - you can remove the push cable to get reduced throttle pull. The second throttle cable is to keep the honda lawyers feeling happy they won't get sued by someone sticking the throttle.
2. The newer XRs (starting in '96) come with a front brake master cylinder that has a smaller piston. This makes it less effort to brake. If you can dig up one off of a CR that will fit - it is the same thing. I think I bought one off of a '95 CR way back when - but be careful - different years mount differently at the master relative to the front brake line.
3. Remove the resistor in the spark plug cap and replace it with a hunk of copper wire the same length. Look up inside the spark plug cap and you will see a straight notch - stick a very small flat blade screwdriver up there and unscrew it - a small resistor and a spring will fall out.
4. When I was young and burly I would remove the decompression cable for easier starting (well it makes it a little harder to kick over - but it starts "quicker"). This is the cable that runs from near the kickstarter up to the cylinder head. It holds one of the valves open until the kickstarter is disengaged. If you take it off you are building compression from the "git-go" and also if it is adjusted wrong the bike can be a real pain to start - so I always took it off.
5. The decompression lever is below the clutch lever in a location that is hard to reach. I like rotating it around so that the lever faced me and I could grab it with my thumb coming into a corner (if I stall it and want to get it rolling again). After rotating it into this position I would trim away a notch from the grip so that it pulled into the bar without interference.
6. I used to buy white brother's megalloy pipes because they were so dang light - but they don't make them any more and noisy pipes are no longer vogue anyways... The stock pipe is very good. You can pull the baffle out of a '91 and the noise isn't all that obnoxious and it will work better than most aftermarket pipes. Otherwise, I would stick with stock and dig up a different baffle that flows a little easier (like one from thumper racing).
7. Remove the backfire screen from the air filter or just buy a uni that comes with a free flowing cage. Do not, no matter what you do, buy a k&n air filter - it may flow more per unit area - but in this case the back of it is metal - so if someone can make an argument that the metal somehow flows air better than foam - then go for it.. :cry:
8. The stock tires on the '91 XR are an IRC VE-35F and a VE-33 in the rear. Both wear like iron and I used to run VE-33s religiously in the rear until I discovered michelins which work much better in the mud. The stock front doesn't work well anywhere - it is a six ply desert tire - I like running a michelin m-12 front tire much better.
9. There are alot of aftermarket parts available - countersprockets, sprockets, levers, etc. Some honda oem parts are much better than aftermarket - stock honda levers will bend and not break. Aftermarket levers are very brittle and will snap right off. Another piece that I would only buy from honda was countershaft sprockets. The stock honda piece fits better and is of "the right hardness". I learned my lesson after wasting a countershaft on one XR because I was running a super hard sprocket. You want the countershaft sprocket to be softer than the countershaft that it is riding on so that the countershafter sprocket is the one that wears out. :cry:
10. The stock springs on your '91 will sack out quickly and leave the bike riding very low in the stroke. Replacing the springs with aftermarket springs will help greatly.
11. After riding for a bit the front fork will build up pressure and get a little harsh. Run zero air in them to start off with and then bleed them after riding for an hour.
12. Safety wire the grips on.
13. I like to put in a zerk fitting in the steering head and pump the steering head full of high temp grease. After every wash, I would pump a little grease in the steering head to force any water out. Doing this makes the steering head bearings last a lifetime. The oil cooler is on the steering head and will warm it up - so be sure to pick a high temp grease - otherwise, grease will be oozing down your fender, and it isn't pretty.
14. The rear shock linkage on your '91 comes with grease fittings :cry: Honda sells some moly paste that works well here. I had another grease gun that would use for this purpose (loaded with pro-honda moly-50). After every wash - just a tiny squirt to force any water out.
15. I also added a zerk fitting to grease the brake pedal pivot. You can drill and tap a hole. Install the zerk and then file the threads off that protrude into the pivot itself.
15. The stock bars are very low and would strain my lower back. I used to run with CR mini-hi's way back when. A taller bar is much easier on the back - a CR-HI bend works well. For tight woods, I cut mine down to 30.5" to clear the trees a little easier.
16. For better bottom end throttle response, you can adjust the intake valves "a touch" on the loose side. I used to adjust both the intake and the exhaust valves to 3 thousandths of an inch clearance.
17. Change the oil often. If you live in a colder climate, a synthetic oil will let the bike start a little easier. Diesel truck oils work well in the XR (or any 4 stroke wet clutch app) - Delo-400 15W40 is great. If you want to go synthetic then don't do so to stretch out oil changes. Always change the oil often regardless of what type of oil you decide to use.
18. Oh yeah, don't use gooey commercial chain lubes. Hate em - they stick to everything and really attract dirt. I use tri-flow -alternatively use 90W gear oil.
19. After washing the bike spray the engine cases, header pipe and chain down with WD-40. WD stands for "water displacement". Doing this will displace water and prevent corrosion on these items. If you strip the header down and spray it with WD-40 after every ride it will end up "blue-ed" and nothing will stick to it (kinda cool).
- jeff
I really appreciate the comments guys and i look forward to learning a lot and having many good rides in the future. If you got any more tips keep 'em coming.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
