Difficult Decisions - head......
Head decisions... So now that the motor is apart and the head all dissasembled I am left with a difficult decision. Do I send my 04 head out to get new copper seats, new valve guides and clayed as well as port and polish or do I just buy an 05 head? My machinist can do my valve seats for $150 and then I am going to have somebody else who builds race motors do the rest of the head work to the tune of $175. So bascically I can have a head thats better than new (and hopefully way more reliable) for a total of $325........
what do I do? does the 05 head come with guides or do I need to order those seperate? Are the seats in the 05 heads the same material as the 04?
please give me your opinions..... thanks in advance...
Well, How much is an '05 head?
As far as differences, I dont know about the seat material, but the ports are different and made for more low end power.
The '05 head is $220 and it comes with guides. The seats are the same material as the '04. The '05 has much better low end, while a ported '04 will have more top. What kind of power do you want? Personally, I prefer the '05.
Well if I send my 04 out the guy doing all the work is going to taylor the head to how I want it. I race supermoto (top end power) and hare scrambles (low end) so I want basically alot of midrange. He can clay the head to make it oval like but not as much as a 05 so I wont loose any top end. It was a stock X motor but is going to have a Gen 2 crower cam, and a wiseco hi comp piston. I can live without having all the low end I have right now but am definately looking for more power up top. When i get on the supermoto track it feels like the top end is signing off way earlier than it should, i was happy with it till i rode a R and it felt much strong up top. i really wouldnt mind going the 05 head route I am jsut scared that the seats are gonna destroy my new PC valves.....
Think about the timing, too. The '05 heads are backordered everywhere. Some have already been waiting weeks.
I went with the '05, but honestly, I didn't put much thought into it. To me, the price for the new head (compared to getting the seats done on the '04), and the low-end gains, made it a no brainer.
But, I'll be waiting, right along with everyone else. Oh, and I went with stock valves and PC springs.
the 04 head can be epoxyed up and ported properly will flow more air even with the cross section closed up at the apex of the bend and the guide area .the 05 head should be able to produce the same results with out the epoxy .ampco bronze for seats is ok but if you want the good stuff it would be copper beryilium or my nbc-1 alloy thats being used in some top fuel cars now .I will see about digging the stock and modifyed flow numbers from the crf head out and posting them im not looking for work here just trying to help im covered up right now .Ron
05 head
increased velocity on the intake ports
larger valve seat area on the intakes.
Improved starting point before you start having magic done, and improvements made my Honda R&D.
Same reason why when the Ti wears off my valves, I am going to the 05 head instead of rebuilding the 04.
HR
:cry:
:cry:
I rode an 05 and my 04 back to back. My bike only has a 52 sprocket on it and I didn't see much difference between the 2 at all. If anything the 05 felt a little smoother (more electric) down low.
ron .... i assume that head is an 04 then since it was epoxied?
I havent got a 05 head yet i hope that the same or better results will come from the 05
well that will change one of these days! I have a friend and once the stock valves crap out, i will have him send you his head.
I'm VERY pleased with your work on my 450 :cry:
  • Similar Content
    • By Kadensmith44
      I’m wanting to powder coat my bike but it’s all new to me. I’ve got a powder coater picked out that I’ve heard is good for what I’m doing. I’m not 100% what kind of sand blaster I need and what kind of media. I have also heard you can’t cook in the oven after you’ve baked your parts is that true?
    • By luke8500
      Hi all,
      I have a 2004 honda crf250r and it wont start hot at all. The motor was just rebuilt with a new cylinder and piston. The valves were just adjusted. It will start cold in 1 or 2 kicks with choke but as soon as it gets hot it wont start. If you bump start it the motor will just turn over without starting.  sometimes it will start. It runs great until you shut it off.  im thinking its either a fuel issue or an electrical issue. Any help would be greatly appreciated.
    • By SandSoldier
      Hello! This listing is for my 2007 Honda CRF250R dirt bike. Last winter I spun the rod bearing and just recently finished rebuilding it. Selling to fund new bike. I am currently the second owner.
      Current registration valid until 2020, pink slip in hand.
      Fresh parts:
      -top end kit: Wiseco; forged, moly skirt coated, 12.9:1 comp ratio (new wrist pin, gaskets, etc)
      -cylinder: new OEM
      -bottom end kit: Wiseco; (new bearings, seals, etc)
      -oil pump: new OEM
      -head studs & nuts: new OEM
      -fresh oil and filter
      -all tolerances checked in top end
      -valves adjusted
      -carb adjusted
      Note:
      *rebuild was done by my dad (master tech at CAT) and I (4th year mechanical engineering student)
      *has maybe 15 minutes on new parts, IT HAS NOT BEEN PROPERLY BROKEN IN YET
      *I have email receipts, pics of rebuild, and old parts as proof of rebuild, just ask and I'll show em off
      Other parts:
      -90% tread on front and rear tires
      -excell takasago front wheel
      -custom aluminum skid plate
      -wrap around hand guards
      -spark arrestor
      -kickstand
      Feel free to ask for any more specifics or pictures!
      LOCAL PICK UP ONLY
      Thanks!
    • By Matt Ray
      Okay so the title is a little vague.
      So it was having trouble idling and even starting when I first bought it about a month ago for $2k.
      So I did a rough clean of carb, looked up on YouTube, Forums, Etc on how to do it. I only cleaned jets with carb cleaner and sprayed around the float bowl area and such, so not too extensive.
      Did that and I took it out to a park, It would start up right away mostly, few kicks sometimes, but when I got it started, I had to keep the choke on. Right when I was ready to go fast and go up to 3rd and 4th gear I'd switch it off and it would work fine and sound fine and everything, but when I slowed back down and coasted around 1st gear i'd pop it back out again because it sounded like it was going to do. I have some videos if people would like me to link to them.
      So after that I decided to take it apart and replace spark plug with OEM NGK R0409B-8, replace main jet from a old 170 to a new 170, replaced pilot jet from a old 40 to a new 42, and kept starter jet the same just made sure that wasn't clogged, ordered a new adjustable fuel screw and used that.
      and it was still having a little bit of problems! I just started up today and the day before today. It would run only with choke on, if i twisted throttle in neutral it sounded pretty good, no gun shot noises or anything, pretty smooth.
      If I tried to take choke off it would die immediately. So I started it back up again, took around 6 kicks.. So again with choke on it sounded like it was starting to lose power and RPM's would drop so I'd twist throttle a few times and it would stay idling.. then after a small amount of time, start to sound like its about to die again... so I would rev it up again, and repeat..
      Fuel line isn't clogged, flows fine.
      I tried fuel screw everywhere between 1 and 2 turns out..
      I checked valve clearances, and I'm no expert but from the videos I watched the slipped underneath intake and exhaust with only minor force.
      So I'm lost..
      Maybe float bowl is messed up? Should I just do a COMPLETE carb rebuild from videos I've seen on youtube, like this one -> https://www.youtube.com/watch?v=3AXb9UprT30? Or what?
      It's getting annoying taking it apart all the time, I jsut want it to start up quickly and run well!!
      Thank you!
      Austin, TX, Elevation 600ft, where I ride its around 900ft
    • By Bryan Bosch
      WASHINGTON, D.C. – August 16, 2018 – (Motor Sports Newswire) –
      Honda Recall Summary:
      Name of product: CRF250R Off-Road Motorcycles Hazard: The clutch outer can break, posing crash and injury hazards. Remedy: Repair Recall date: August 16, 2018 Units: About 3,200
      Consumer Contact: American Honda toll-free at 866-784-1870 from 8:30 a.m. to 4:30 p.m. PT Monday through Friday or online at http://powersports.honda.com/ and click on “Recall Information” at the bottom of the page for more information.
      Honda Recall Details:
      Description: This recall involves all 2018 Model Year CRF250R off-road motorcycles. The recalled motorcycles were sold in a red color. The names “HONDA” and “CRF250R” are printed on the sides of the motorcycle. The model name and model year are printed on a name plate label located at the front right top of the frame, near the steering head.
      Remedy: Consumers should immediately stop using the recalled off-road motorcycles and contact their local authorized Honda Powersports dealer to schedule an appointment for a free repair. Honda is contacting all known purchasers directly.
      Incidents/Injuries: American Honda has received 19 reports of clutch failure, including two that led to engine lock up. No crashes or injuries reported.
      Sold At: Authorized Honda Powersports dealers nationwide from November 2017 through July 2018 for about $8,000.
      Manufacturer(s): American Honda Motor Company Inc., of Torrance, Calif. Manufactured In: Japan Recall number: 18-759 This recall was conducted, voluntarily by the company, under CPSC’s Fast Track Recall process. Fast Track recalls are initiated by firms, who commit to work with CPSC to quickly announce the recall and remedy to protect consumers.
      The U.S. Consumer Product Safety Commission is charged with protecting the public from unreasonable risks of injury or death associated with the use of thousands of types of consumer products under the agency’s jurisdiction. Deaths, injuries, and property damage from consumer product incidents cost the nation more than $1 trillion annually. CPSC is committed to protecting consumers and families from products that pose a fire, electrical, chemical or mechanical hazard. CPSC’s work to help ensure the safety of consumer products – such as toys, cribs, power tools, cigarette lighters and household chemicals -– contributed to a decline in the rate of deaths and injuries associated with consumer products over the past 40 years.
      Federal law bars any person from selling products subject to a publicly-announced voluntary recall by a manufacturer or a mandatory recall ordered by the Commission.
      Source: Consumer Product Safety Commission
