Easy question: spark plug deep socket size?
Cant get the 13# torque set without a socket and need to get a deep socket for it. What size? Got a misc box os sockets but none fit. Hats off to you all.
Gunslinger,
The correct spark plug socket you need to purchase from your local auto or hardware store will be a 5/8" deep. The store will probably have one that is designed specifically for spark plugs, and will have the foam insert down in the socket to hold the spark plug while installing / removing.
Mine is Craftsman, from my local Sears store. Or is it K-Mart now........
coeshow, I just checked my 150 and a 5/8" is to small. Unfortunately my largest deep socket is 15 mm. But an 18 mm wrench fits with a little bit of play. So, sorry to disagree with you but 18 mm is the correct size.
Cheers, :cry:
As per your signature, "Tourque rules" :cry:
The concern is over achieving the recommended 13 lbs of torque for the plug, something the little free dealer tool wont help with.
As opposed to a post I made a while back titled "How many Ummmphfs in 12 lbs of torque?"
Different plug brands use different sizes. NGKs are 18mm, I believe Champions are 5/8". I think Densos are 18mm as well.
--Fillmore
Actualy the owners manual tells you how many turns past snug is about 13ft pound of torque for the little honda tool
To CRf150#319,
You do not need to be sorry as you are absolutely correct! The 150's and 230's spark plugs do take an 18mm socket. My mistake.
Gunslinger,
I hope you purchased the correct spark plug socket! I apologize for informing you incorrectly as to the proper size for your 230. I've been working on some modified CRF50 stuff lately, and they DO use the 5/8Th's socket for the plug. Again, I apologize for my misinformation.
No worries. I wait for a lot of repleis to come in before making decisions. I got the 18mm from Sears, fits perfect. Thanks. Your info has saved my a$$ a couple times before - I can let ya slide once :cry:
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
