Race Sag
I ride a 1999 xr400r My weight is 250 6'4"
trail riding and some hill climbs. Standard spring is a 10, installed 10.5 need to set my sag.
What would be my Sag?
Dwight says the race sag on an XR4 should be 105mm.
I weigh 180 with all my gear on, and I have the stock spring. My race sag is set at 105mm which put my static sag at 30mm.
I'm 5'-11" 235lbs I ride harescrambles, trails and some hills and the shop set my race sag at 85mm. Just checked my cheat sheets they gave me on the setup, my installed shock spring rate is 10.5, preload was set at 13mm, sag is 85mm, rebound adjuster is 12, nitrogen pressure is 215psi.
Hope that helps you out :cry:
