Leaky Fork Seal and Scratch on Fork, How To Fix
I have a scratch/nick on the fork tube, just replaced the seal and am still getting some leaking.
Any one know how I can buff out the nick with out making things worse, and is this what I should do to fix it.
As I understand it the scratch will just tear up the fork seal.
Thanks in advance
Use some fine grit emery cloth and sand down the burr or scratch in a circular motion. This will take care of the problem.
If you have a deep nick, do the same as stated above, then add a drop of super glue in the nick. Let it dry, then sand it down smooth. This will fill the nick up smoothly.
Afterwards, use some steel wool and polish your entire tube.
Grasp the tube with the stl wool, then push and pull the tube while rotating it. This will create a x-hatch on your tubes. Some techs do this and some dont. Its all preference.
I prefer it.
Good Luck, KaBooM
Ive fixed a couple nicks. I use a piece of 1000 grit wet or dry sand paper wrapped around a file so its backed firmly. This prevents you from sanding around the nick more than the nick itself. Kinda like block sanding a car...
Also a fine wet stone will do nicely because it is a FLAT HARD surface and if done corectly will only take down the raised portion of the nick or burr. Then finish it of with 1000 grit or some thing like that. In my expirience ive never filled the missing matireal with anything but i do like the supper glue idea. The main thing is to get rid of the nick to prevent cutting the new seal. :cry:
I would'nt recommend anything more abrassive than 2500 grit wet/dry w/supension fluid as a buffer, Granted this may take a little more time but your less likley to damage the overall finish.
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
