Part number for Magura 13mm master cyl.
Anyone have the part numbers for the 13mm Magura Radial pump master cylinders? Also what's the difference between the 190 model and 195 model?
I need the info. to order. I'm using a 4 piston Brembo caliper. Thanks in advance. :cry:
I'm not sure of the part numbers but the 190 is alot slimmer design than the 195 and also has a shorter lever and comes with a resevoir. The 195 model is currently back ordered from Magura USA.
Hope that helps..
MikeD
Sttars #77
