Vapor lock in gas tank
I noticed a long time ago that if I fill the gas tank all the way to the top, my bike would have serious problems. The first couple times it happened, I didnt know what it was. The bike would suddenly die while doin 55 on the highway, very scary.
It turned out it was a fuel vapor lock problem from the tight locking gas cap I have (CA s model). Holy crap, I just remembered, I should have added this to my last post about my drz havin problems, cause when I stopped my bike, I tried releasing the pressure from the gas cap and there was a lot released. I was just wondering if others with the locking gas cap have experienced this vapor lock? Slobiker
Very common with CA DRZ's... due to the vapor recovery system.. You do not have a tank vent,, as do other non CA tanks.. Yours has a vent system that goes to a charcol canister,,,, That canister gets plugged up with raw fuel,, then you no longer have any vent,, and the bike stops running. Dump the vapor recovery system,,problem solved.
bronco is half right. it's not the canister that gets full of fuel, it's just the line to the canister. the line dips way down on the side of the bike and fuel from an overfilled gas tank sits at the bottom of that hose and causes the vacuum. you can actually unplug the hose from the little valve thingy there and dump the fuel and keep on riding.
but you're better off just removing all that crap.
cheers
droo
guys, can I get some detailed instuctions on how to remove all CA smog crap please!!!
cheers
droo
While I'm sure your observations are as you have seen.. :cry:
The charcoal canister does become saturated with fuel in many cases. I've personally seen one,, that raw fuel was dumped out of,, and directed this fix to others,, who found the same...
Disconnect canister at the tank,, connect vent line and run up and under seat.
Disconnect Purge hose at carb. Cap off the purge port.
Ride bike. Toss crap in garbage can :cry:
Bronco, I'm a little confused.
Do I disconnect, then plug the rollover valve? and what do u mean when you say to connect the vent line and to run it up and under the seat? What is a vent line and where do u connect it to?
also, what would you suggest to use to plug the purge port after disconnecting the purge hose.?
<Ride bike. Toss crap in garbage can >
Look...better put it in a box and on a shelf just in case - just in case that is - CA starts bike emission inspections. With the nutty krap we already have in this state (C.A.R.B.!) I wouldn't be surprised if we have to start rolling our bikes in every two years like our cars. :cry:
:cry: Disconnect the line from the canister AT THE TANK.. not the roll over valve,, at the tank.. then connect a length of vent line (any fuel hose that fits the nipple at the tank will work) and run that line a few inches to a spot under the seat. This is your new tank vent,,, if /when you fall over,, fuel will/may spill from that vent a bit, until you pick your bike up. That is the reason to add the vent line and move the opening away from the bottom of the tank.
Plug the purge port with a vacuum cap,, Pick um up at any auto supply store.
I seriously doubt CA is ever going to test bikes made currently. bikes made in a couple of years maybe.
I valid concern,, One I would not get too wrapped up on,, but sure,,if ya have a place to store the parts,, Put um away for another day. :cry:
Typical California smog junk on the motor. We don't get the bike so we don't see the stuff they stick on your machines. We get 49 state bikes, California gets it's own junked up clogged up motorcycles. I hate even writing that but it's the truth. prairiedawg :cry::cry:
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
