1984 xr250r restoration
ok i purchased an 1984 xr250r today for 100$can for my dad.so needless to say it needs work but i want to present it to him in mint condition. we've never rode together and now he's 52 and about time he started. moms gonna be pissed but to bad.So apon first visual inspection the olny thing its missing is the carb and some choke looking mechanism on the top right side of motor, its half there. The motor strokes fine and gearbox works fine. Front suspension sloppy but rear seems fine with no play. Brakes work good, is disc front drum rear.Last known use of the bike it worked great just someone played with the carb and now its gone. I know the first step is gettin a manual but i would like to hear from everyone about anything on this bike. Frames mint wheels are mint. I'll spend whatever it takes to go on just one ride with him and im starting tonight. I'll have many ?'s over the next few weeks .Im a rookie at all this. Anyhow thanks for any advise in advance.
Cool. I just bought an 85 xr350 a few weeks back. Trying to glean whatever info I can on these good ole bikes.
Watch ebay for manuals. i watch it for parts too. There are guys parting out al the time.
If it's the decompression lever stuff you can take the cable off as you'll never need it.
The lever on the head is the decomp.
Carbs are gonna be expensive for a good set. Watch ebay. I wouldnt sink too much money into it. Take some pics so we can see what kind of shape its in.
These bikes are notorious for running hot and frying the head/valves. If you can find a set of carbs cheap then make sure to run good synthetic motorcycle oil. Its really not a great beginner bike for tight stuff, it needs to be ridden at a brisk pace or it will get hot. If your dad is just going to be riding fire roads then it will be fine.
open the valv cover and crank it over a few times see if valves operate properly. ck compression, igntion spark, does it shift through all gears? post pics
Looks better than I expected. :cry:
If it has good compression and shifts fine then I'd find a good set of carbs on ebay, slap them on and be done with it.
picked up my carb today for 150$ and a air filter basket 10$ and a chain for 32$. I now need a clutch cable and piece that connects from carb to motor. I'm gonna throw some oil in the cylinder and check the valves and compression
It looks as though the insulater (BETWEEN CARB AND ENGINE) is on the head already. I just purchased one new from hONDA for $50. You might want to replace it anyway, chances are it is old and brittle Dont need any cracks/leaks at that point.
You keep saying carb. Is it a dual carb, cuz the 84-86 XR and 84-87 XL had dual carbs.
Looks as though the auto decomp (right side of engine) is all there. The cable that runs from it is all there.
If you ever come across a used head in good condition swipe it up. It took me over a year to find one I would purchase to complete my project. Wish I had a spare cuz these bikes are known to run hot. The dual carb fire pumper makes em run hot. Extra power = extra heat.
ya your right its dual carbs . and I'll check with my wrecker i think he has an extra head.I'll price it out and pick it up if i can. Good idea thanks ! the project continues.
The other day there was an 84 head on ebay for $50 Buy in Now. If I had 50 bux I woulda bought it already.
I bet someone bought it already though. EDIT: yea its gone.
Ohh yea and if you find an intake manifold thats cracked, let me know. The aluminum has to be intact though.
I had a cracked intake manifold (insulator) and all that is left is the metal. All the plastic was so brittle it fell apart.
I may still have the metal if you want it.
t.
My 85 350 is single carb, did they stay with duals longer on the 250?
Sorta. The dual carbed 250 and 350 models lasted 2 years, but the 350 was for 83/84 and the 250 was for 84/85 (86 has a single carb). They contined the dual carb XL for another 2 years. The XR600 has duals until 87 IIRC.
So, you are going to weld a single port onto the dual port? What do you shave off (or is the single carb shorter?) to make the carb fit with airbox and all connected?
I will look tonight on the work bench to see if I can locate the metal piece. Where will I be shipping to?
Other than tuning, what's wrong with the duals. You don't think the increase in power is worth the dual carb headache? I wouldn't know the difference, just heard the dual fire breathers were the shiznit during their day.
I'm going to shave down part of the dual carb manifold. Honestly I'm not 100% sure how I'm going to do it, I havent gotten that far. I've still been looking for a spare manifold so I dont have to cut up the only one I have.
The problem with the duals is the massive flat spot off the bottom. Up top they work great, but its a real bear to loft the front wheel at any speed. I'm going with a Keihin FCR 37 pumper carb. Its big enough that I shouldnt lose anything up top (in fact I'd rather have a 35, but I would have had to basically pay full price for one).
You're going to be shipping to San Luis Obispo. When you find it let me know how much the shipping is going to be and I will paypal you the money for shipping.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
