04 KX250F Dog when cold
Hi Everyone,
I have recently purchased a used 04 KX250F. It is an absolute dog when cold,meaning when I start it with full choke - it will start ok, but if you turn the choke off too soon it splutters and dies...horribly...however once it is warm it idles ok...and runs very, very well on full throttle....
The other issue that may be related is that it backfires on de-acceleration. As this is not a new bike, I know the previous owner had pro-circuit pipe on the bike and replaced it with the stock pipe when I purchased it.
Does anyone know what might be causing these problems?
Well Im not sure about the starting isue, But it is noraml for a cold motor to die when you turn the choke off if the bike is not warm.
But for the poping on decel, well that means that its eather too lean or you have an exhaust leak somwhere, I would start by turning the fuel screw out a half a turn, and keep going out untill it stops poping, But if you go out more than 2 1/2 turns go with the next size bigger pilot jet and start the fuel screw back at a turn and a half out, and go from there.
The rule of thumb is.
More than 2 1/2 - 3 turns out, go to the next size bigger pilot.
Less than 1 turn out, go with the next size smaller pilot jet .
:cry:
Hi Everyone,
First I would check the jetting in the bike. If he had a different pipe on it the jetting has probably been changed and I think Pro circuit recommend some pretty lean jets. Stock jetting is 178 main and a 40 pilot. I'm running a KX250f with 175 main and 42 pilot and a RMZ250 with 178 main 40 pilot. Both bikes are different and the KX seems to have more snap down low.
Like the other posts say check that everything is tight and where it should be. My bike used to pop and backfire when it was cold but the richer pilot and warmer weather cured that. The richer pilot will probably help with the starting as well.
The cold weather thing sounds normal.
and are you sure it's backfiring or just cackling? My 250f and both of my friend's 250f's cackle on decel. We both have the jetting adjusted fine, unless it's horribly loud, it's a normal 4 stroke sound.
  • Similar Content
    • By Toms.abpg
      Just bought this bike and the pop on decel is horrible, looks like I’m gunna have to try a Tokyo mods remap. Anyone had success with this ?
    • By _Cloudy_
      Hi, I have just bought a kx250f, 2013 with a freshly rebuilt 2016 motor in it, this is my first time on these forums, anyways, I have also bought a lowering link to drop it 4 inches on the arse, I was wondering if anyone knows how much I should drop the forks?
      I havent put the lowering link on yet.
      Thanks.
    • By Zach Miner
      Recently had issues with the original fcr carburator that was installed in my 2009 kx250f, tried jetting multiple time and different gas and the bike would only run with the choke ziptied out. Do I went ahead and purchased the lectron gen 2 4 stroke carburator kit, was kinda expensive and I was kind sceptical but after my first ride all I got to say is wow. The only adjustment I have done it set the idle, the bike runs amazing and feels as if there is more power than before. The kit came with a new throttle tube assembly and a g2 throttle tube with adjustable cams for throttle response. I highly recommend if you have a carburator on your four stroke and don't want to get a new dirtbike that is fuel injection then go the route of throwing out that junk fcr carburator and get a lectron gen 2 carburator for your old 4 stroke
    • By DirtbikeDon
      I own a 2012 Kx250F that I would like to make street legal if possible and I recently saw Rocky mountain I believe sells these battery packs that sit in the airbox for bikes without batteries that looks too good to be true and a headlight and turn signals like a conversion kit basically and I was curious as if anyone has had luck with those or if there junk it would be nice to make my bike street legal for short trips or just have lights for trail riding with friends that already do if possible any tips on converting it?
    • By kylesmith_14
      The launch control only lights up when you first start up the bike when you try to use the launch control it doesnt light up at all ive tried 1st 2nd and neutral for 3+ seconds ive cleaned the connections and also cleaned the neutral saftey switch or gear selector and still no luck any help would be appreciated
