who needs a E spring?
How about a trade? I have a stock rear spring E. I need a S spring for my weight. It seems must people want the S spring maybe a lot of us need to lose some lbs.......
I think you have that backwards. Everybody wants the E spring for the S. The S models suspension is too soft especially for a 200lb+ rider. But if your sure you want to trade your E spring for an S. I'll swap you. How soon do you want it? :cry:
I have a 2003 "S" model and I only weigh 160 lbs so I want the lower rate spring. :cry: PM me your address.
depends on what the rider weighs and wich bike.i was just throwing out the springs weights.
the S spring is a popular choice for E models.
Interesting, I'd always been led to beleive it was the otherway around.
I have an '01 S and I weigh 190 with full gear. ANd I ride alot of deep nasty whoops. which would you recomend?
Burned,
RaceTech says that the Industry Standard is +/-5% which means a spring marked 5.0 k/g/mm could actually be 4.75 to 5.25, so a spring marked 5.0 and one marked 5.5 could be the same. I guess my question is at 230lbs and racing harescrambles should i trade for a "S" spring or spend the 100 or so bucks for Racetech and have a spring that may be a more accurate spring rate? Thanks for all the help over many different topics.....Postie I will trade with you even if I buy from racetech.
Why do people fuss so much about spring rates?
So what if your 10-20lbs heavier, lighter then reccomended spring weight/rider weight for your bike. I mean sure you can change it if you have the money, but what if you put on a few lbs, take off a few...
Okay I'm not saying dont do it cuz it helps. I'm just saying, remember its just as or actually WAY more important to get the valving right.
Vavling people...valving :cry:
I thought it was the other way around...getting the correct springs are moer important, worry about the valving second. They are kinda tied together anyway.
Burned,
call around to some local suspension shops.one of them should have a spring rate tester and can tell you exactly what the spring is.
Burned I have a DRZ400E and I weigh about 250 lbs in full gear. My bike is to soft. What do you recommend besides a better diet :cry:
I believe the variation is spring rate is correct as mine is an E 5.3 ADVERTISED spring(stock) and with 95mm of rider sag she's right on 25 mm free sag which is right in the ballpark and I'm 200lbs. If I rode hard at a MX track I may try the 5.5 but for the bush it's perfect :cry:
I learned to do my sag setup before assuming I needed a stiffer/lighter spring. It may be fine for your type of riding or weight.
it goes by rider wieght no gear...........
