[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
XR100 Wiseco 2mm over jetting ?
I have the Wiseco 2mm over (55mm) piston along with Hotcam and FMF Powercore exhaust, I have the ATC200X 24mm carb, I am located around 1000' above sea level, I bought a carb rebuild kit, it came with 108 and 110 hex mains, what main and pilot jetting should I be using?
