Using non-TPS carbs on the 400s
What is the TPS doing anyway? Does it advance the timing with throttle, or retard it? When switching to an FCR or Edelbrock carb, do you simply leave the TPS disconnected?
Thanks
It has but limited use,, and most can not tell if it is connencted or not,,, TRy it your self. Go for a ride, come back, have a friend unplug or not the TPs, go ride, come back,, have him do it again,,, then one more time... Now see if you caouls telll which times the TPS was pluged in or not.
My bet is, you will not.
Many have replaced the BSR with a non TPS FCR,, No issues at all.
