Jumping a CRF 450 VS 2 stroke????
I just bought a new CRF 450, and it looks sweet. I am breaking it in on Sat. My questionis how much differant is it to jump vs a two stroke? I mean jumping will be easy, but like on a two stroke I speed jump ( floor it, and let of on the face, stay low) The compression will slow me down I am thinking. I just wanted to know if their is any leapers in hear, and what they do to stay low and go fast. Any help would apprecaited. ANy other tips, for the conversion would be ehlpful to as well.
Thank in advance TTERS.
Ryan :cry:
I have a 04 CRF450 that I jump just like my old CR250. I have gone off jumps with a lot of momentum and the throttle chopped and have never had a problem. The engine braking seems very minimal. Of course, body english plays a part any time you come off a jump with no power but my experience has been that it is not a problem. Jim
My CRF jumps just as good as my old smokes did. The engine braking actually is very little with these bikes. Most people think its like the XR bikes, where you never use the brakes to slow down much, but its really not.
You will find yourself jumping as good if not better on the CRF, at least I did.
if it does seem like the engine braking is too much, consider a slipper clutch... they make off throttle feel like a two smoke. i love mine, and i know that burned does too!
dan
OK, I never heard fo that. Did you used to ride 2 strokes? I went an broke it in, and it felt good. I have to change the gearing, as it is to low. I am going from a 13/48 to a 13/50. I think that should help. Then I can tell if I need this clutch you speak of. Did the cluth affect anythign else?
I know for me it took some getting used to.
Several times I chopped the throttle on the face of a jump and wound up riding the front wheel like a unicycle! I ALWAYS leave a little throttle on all the way through the jump.
Jumping the 450 is a little different but if your a good jumper the transition will be real easy to adapt too. The first thing is Don't let off the throttle off the face, it will want to nose dive, the next thing you'll notice is the huge power, You can clear about anything, And last, they are a little heavier. All in all though I prefer jumping my crf to my old kx 250, if you loose a little momentum or if its muddy out, you just roll it on!!! Troy vet140
Because of the weight and engine characteristics of the bike it will take some getting used to (like 20-30 minutes) but you'll get the hang of it and it'll be like old times.
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
