Shim stack suggestions
I cant remember if my 03 CRF has a single or two stage stack. If it does have a two stage stack, it need to be considerably stiffer in the second stage. Anyone have a stack suggestion?
It would help if you would post your existing stack. So you require more HS damping?
The '03 is indeed a two stage stack. Toss the crossover ( 10x24 ) shim and build you a single stage stack--- especially if you are doing m x only.
