gas
what kind of vp should I run and also I herd that you should mix regular gas with it
The only VP fuel that gets a real gain is Ultimate 4 because it's oxygenated. You do not need high octane for most 4 stroke motors. U4 is 94 MOTOR octane which is plenty for even modded 4 strokes. If you mix it with pump gas you are killing the potential for the gas. It adds power because it's oxygenated, you add regular gas to that you are halfing the oxygen content of your fuel.
VP claims 6% increase in power in u2 and u4 fuels and i believe every word of it. I felt the difference.
running 110 or c12 only raises octane, which won't help on a motor that doesn't need higher octane. Oxygenated Leaded fuel will add the power.
