Just put the 3.9 on
I bought the clear Clark 3.9 over Christmas for myself and just got around to installing it. Install went smoothly. I decided to put the little wire support on. It was easy to do and it can't hurt to have it there. The stupid Yamaha dealer charged me over $8 for the fuel cap vent tube. Ripoff.
I had to grind about 3/16 off the seat tab on the tank to the the rear of the seat would line up with the bolt holes and I bend down the tab that could rub against the tank.
ATTENTION: Check the inside of you tank before you install it. I found a ball of raw fiberglass attached to the inside of the tank. I had to get a long screwdriver and scrape it off the side. It was about 1/2" in diameter and was partially embedded into the plastic. Why there would be fiberglass in the tank, I don't know. I assume these tanks are injection molded in a steel die... :cry:
Someone posted that the process was "rotational molding" not injection, and that was why some of the tanks (especially IMS) have variations in their size, etc.
Maybe one of our fellow TTers can explain how its done. I know the IMS instructions tell you to clean the inside before you use it. I think that's pretty crappy. They ought to make the tank clean and ready to install before they ship it.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
