Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
Need a new front tire, any suggestions? Feedback wanted
On monday, I'm getting a new front tire. My Brigestone e661 was a good one, but is now chunking on the sides.
I'm probably gonna get a Dunlop 739 front or a 756. Has anybody used these tires???
Any feedback would be appreciated. Is the 756 front better than the 739 front??? I dont know which one to get. Thanks for any input, Slobiker
You have to buy the tire that matches what you are going to ride on. Being you have an "S", I would imagine you use it on the street.
I had an almost new 739 from an XR650R and I gave it away. It was better in the dirt than a 490 but, it wasn't as good on the pavement. A 756 is an awsome off-road tire but I wouldn't run it at all on the street.
If I'm going to trailer my DRZ to a riding area I put on the 756. I really like the 490 for a dual sport tire. They wear well on the street. So many of them came stock on MX bikes and were taken off right away. Some racers have kept them back in their tire racks and are willing to sell them cheap.
I've run both the 756 and 739 fronts and much prefer the 739 on the DRZ for the sandy western conditions I ride in. I find it doesn't dig in as much in the sandy turns. 756 for the rear though!
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
