Idle idle RPM......and fuel screw settings..
Got my new IMS tank in, bash plate on, grey wire cut, and Mini-Tach installed. To this point I dont think I screwed anyhting up. :cry:
Now that I have an RPM read out.....I was wondering what everyone has idle set at.......I have heard 1900-2100....that sounds kinda high.......my bike was set at 800 and I boosted it to 1100 which sounds nice, also seems to be less bog at higher RPM.
Allso I have done most of the free mods, bike starts real easily....more easily after I put the new fuel screw in but I still question if I have the right mixture set.
I now have idle set at about 1100...and even after a couple mins of running warming up when ever i pull the choke RPM shoots up to about 2200rpm!!! :cry:
Again bike starts great.........am I to lean..should use fuel screw to richen her up?
Last thing....new 3.4 gal IMS tank fits great on the 05 wr250f......the radiator shrouds must be same as YZ shrouds. Couple spots the fuel lines run real close to engine cylinder :cry: . Any heat shielding stuff for fuel lines anyone would recomend?
Thanks
Glad you got the tach working, now read this link http://www.thumperfaq.com/jetting.htm . At the bottom of the link, under jetting the pilot circuit, the fuel screw set-up is explained very well. I would also recommend the jetting forum on ThumperTalk if you have any specific questions that need to be answered, if not answered here.
Good luck,
