klx300 c/pin offset
Does anyone know what the crankpin off set is on the stroker cranks??
I am figuring I will need to offset by 2.325 to take the bike out to 365 (84mm bore).
Cheers
The stroker/fourstrokeworks pins are offset by 3mm.The crank is overbored by 6mm diameter then a 3mm thick spacer piece is used to lift the pin up by 3mm.
Nobby.
