First Long Ride on '05 Part I need now....
Got all my mods done and went for my first 50 miles plus urban assault the other day.....I have only two complaints.....First problem is the seat, where can you get the best deal on a gel seat? I definitely need one of these......second problem is the much talked about death wings. These do not hook up whatsoever.....could'nt keep the ass end on the trail! After these mods this bike will be top notch.....
I like to thank everyone on T-talk, for helping me spend way too much money already on mods.....
Top Ramen is 10 for a buck, can't beat that I guess.....
From what I've read, the gel seat is just as hard, if not harder than the stock seat. Most people don't like it.
Throw some Pirelli MT21 tires on there for a huge difference in the dirt.
I got a Tera-flex Type II after reading about it here. Over Christmas I got to try it out in deep mud and tight trails in Virginia and it worked great. You can get one here for $85 delivered:Clicky
I put a Kenda Trakmaster on the front. Not the greatest in the mud & sand but pretty good everywhere else. Both tires are DOT legal if that matters to you.
Peanut butter is a pretty cheap source of protein for those of us spending more on bikes than food :cry::cry:
I have read mixed reviews of the gel seat........I'm definiely going with dot approved knobbies.......just have to hang around and find out what works best.....as far as the seat I will do the same....
For tires, I want what wears the least......probably hard to find in street approved......
If you are doing any real off road and not alot on on road blow off the dot and go with m or s-12's front and back. You cant beat them off road. As for the seat ..... go faster so you stand up more or grow a calluse. :cry:
Get rid of that seat strap.
I think most people just throw new knobs on and call it a day. But with set up even the crappy trailwings can hold a line, once moved to better tires afterwards provides the true Magic.
Kenda Trackmasters are really good DOT knobbies and they're cheap as well (as in price) The Maxxis M7000 Dualmaxx are really good as well and are often overlooked, but for the price the Trackkmasters are worth it :cry:
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
