How do you fit CRF throttle cales?
Sure some of you lot will be able to help.
I've just changed my Mikuni carb for a Keihin FCR from a CRF450, along with the throttle and cables etc. When it all goes together the throttle is stiff and doesn't return.
If I only connect the 'pull' cable it works fine. Has anyone else had the same problem?
Make sure you leave a lot of freeplay on the push cable. If you take the freeplay out it gets tight because the cables are working against each other. Also really look at how the cable is assembled in the throttle housing, it's easy to get it screwed up in there.
