My First Valve Check!
:applause:It really was quite easy. Here were my findings: LE .010 / RE .008 , LI .007 / RI .005 So do I need to change shims? If so do I aim for the loosest tolerance? Thanks. :cry:
Did you check shim size while you were there? To me they are all on the tight side although in "spec".
I recently had;
intake left = .005" / .127mm
intake right = .005" / .127mm
exh. left = .011" / .279mm
exh. right = .009" / .229mm
I'm re-shimming both intakes to 2.75mm shims and the right exhaust to 3.10mm shim. You really need to know your existing shim size to calculate what's needs. To gain valve clearance you need to reduce shim size. Bronco78 helped me with this. Good luck! :cry:
OK I just checked shims.
LE 318 RE 330
LI 285 RI 282
They are all "in spec". But the RE is just barely. Should I just change the RE and buy how much? Thanks.
When changing shims it is best to go for the loose side of the tolerance but I would not make any adjustments just because the valves are near the tight side. You do not really have a problem until they are well out of tolerance. You may find that the valves will not require any adjustment for many more thousands of miles even though 1 or 2 are near the end of the tolerance zone. I just checked the vales in my street bike (16 valves). Don't need adjustment and have never been adjusted in 40,000 miles.
Don't worry about. Ride it. Keep track of the clearances and make adjustments when it is clearly needed.
I had an exhaust around the .21mm range at 8,000 miles, 1000 miles later it was at .19mm
I do agree you got time though, and a little more clearance than I had.
If your lucky they'll seat where they are at and not move any more.
I haven't had any more movement since around that 10 to 12k mile area.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
