Odometer gearbox ratio for speedo hookup
I figure any simple small speedo with an odometer would be less than half the cost, and as good as the electronic ones on my E model if I knew the right ratio. Anybody know?
No but they seem to all be the same. Any odometer should work with a odo drive for a 21 in wheel. You can figure it out for your self by figuring how may wheel revolutions in a mile then counting the odo cable turns for that many wheel turns. About 750 wheel turns in a mile.
Again most are the same. Look for a small Honda XL, XRL unit. Baja designs used to sell one
However $75 for a Trail Tech is hard to beat. Or under $20 if you want to adapt a bicycle unit.
