Cam chain slack?
Just did my first valve check. Was surprised by the amount of cam chain slack that I had with my MCCT. Should I take that slack out of the chain? Thanks.
I run mine pretty tight. You'll hear it if it's too loose. After having the cams out to check shims you're exactly back where you need to be on the cam chain, right? And, not to disagree with the other gentlemen but if it were my bike I'd re-shim to the loose side of the spec. Shims are $4 apiece from Ron Ayer and it looks to me that you could drop a full shim size all the way around. Just my opinion...Good luck! :cry:
Adjust the MCCT as recommended,, all will be well :cry:
And I too would adjust the valves.. My personal opinion is,, they ARE to tight now... The wait and see approach is a recipe for new valves,, when you miss the moment they are out of spec,, and being help open....Cuz at that point,, it's time for new valves
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
