reseal
Heavy
Your bike has the traditional damper rod style of forks, very easy to work on. The only tool I would even recommend would be the 41mm seal driver, and you could probably fabricate something to gently install the new seals. Just observe teardown sequence and reverse upon assembly, give me a call if you get stuck.
Take Care, John
