KLX400S Right Rear Pass. Peg
I'm in process of buying an 03' KLX400S. The owner installed a Muzzy full system. He said he had to cut off the right pass. peg to put the pipe on.
Where does the peg mount? Maybe I could weld it back on. Any suggestions?
Thanks
Umm, same area the left one does.. look left,, it goes there but on the right side :cry:
Most folks do not "cut off the peg" they unbolt it,, and use the lower mounting hole to attach the pipe mid mount.
You could reinstall the right peg, then make a custom mount for the mid pipe
