05 CFR250X number plate
Well on the X there is 2 posts on the bottom tripple clamp that hold the headlight on, the R has a single post. I got a capped allen and then drilled a whole and tapped it then used loctite to put the allen in. That way you can swap between the number plate and the headlight if you want to. On the top tripple clamp drill a whole in the middle and get a tap to whatever size bolt holds it on. :cry:
I ended up putting on a Cycra on mine. 2 other X's I ride with put on stock R plates and I don't remember exactly what they did but I think the Cycra fits and looks better.
Got any pictues you could post for us?
