Hot Cam installation Question
Acutely I have two questions.
First: I didn't pick up any of the high pressure Assembly lube that they recommend on the installation sheet (darn). I do have Luberplate that I use for automotive cam installations, will that work? The parts store is open for a while today so could still pick something up if needed.
Second: On new Cam installations "E" exhaust and Hot Cam intake should I run the adjustment on the loose side or tight side?
Here are my initial measurements:
Exhaust: Right .20mm
Left .23mm
Intake: Right .10mm
Left .15mm
Now here is what I am planning on doing:
Exhaust: Right .25mm
Left .23mm
Intake: Right .15mm
Left .15mm
How's that sound?
How's that sound?
Sounds like a plan. :cry:
Actually you may even be able to go looser on some if some of the shims are factory half shims.....
All my shims are full shims:
Exhaust: R 310 L 310 Intake: R 285 L 285
What do you think about using Luberplate to install the Cams?
Well here's what I ended up with: Exhaust R .28 L .25 Intake R .15 L .15
And now that I have it back together it's snowing.
How many miles should I put on it before changing the oil? How about readjusting the valves?
Tim with new Scotts damper, Hot cam intake and E-Exhaust. :cry:
