New bike, and need some suspension advice
I have just purchased a 2003 rm250. I am about 5'9'' 5'10'' and i have rode and owned 250's. I am just now deciding to race in the 250 class (mx) and i know that the 2003 rm250 has Kayaba forks and shocks.
I weigh about 155-160 w/out gear on and i am thinking it needs to be resprung and i also would like a revalve.
I was thinking i could save money buy buying Race tech gold valves and and springs and just doing it myself BUT i do not know hw dificult this is. I have never ventured into the suspension tech department becuase i am afraid of messing it up. I do everthing else on my own so i figure i should learn suspension assembly.
Does anyone have a good link on rebuilding your suspension? I have my Factory Service manual but i don't know what else i need to know.
How long does it take and what special tools would i need?
thank you!
The manual is fairly comprehensive regarding suspension assembly / disassembly. :cry: If you feel compelled to waste your money I recommend the the Gold Valve path, however there is nothing wrong with the stock piston design just modify the valving stacks, change the springs for your weight, you may not even need to change them. :cry:
If you think you are getting confused then send it out to a reliable suspension shop that offers comprehensive after sales service and let them do it all and sit back relax and enjoy your riding. :cry:
thanks,
The thing i needed to know is if i should just get a spring ratio for my weight.
I'm 155 and they are set up for a 170lb rider.
I know i can adjust it but it gets so a point where you can't adjust it anymore and still have it be affective and do what i needs to do.
I guess i'll take it up to town and get it worked over but i was trying to save the extra cash. If i don't take it up i will have money left over for shock/fork gold valves.
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
