**Check It Out**"Little Hands" mod for your kids bikes.
If you're little ones having trouble with the reach from the grip to the brake/clutch lever. Here is a CHEAP, easy way to close the distance and make using the hand controls much easier. Also by moving the levers closer your Young dirtbiker will gain leverage and confidence since they no longer need to struggle with the controls.
Start by removing the clutch/brake perch and drilling a 5/32 hole in the perch and tapping it with a 8-32 tap. insert a 3/4" cap screw and tighten to desired distance. Reassemble and adjust accordingly. :cry:
Brilliant!
Great job, wolf_child. :cry:
Also, a dab of lock-tite will help keep the adjuster screw in place.
Dan.
My 9 yr old took this thing out for a bit this afternoon... :cry: Man, what a difference. According to him, not only is it easier to reach, but easier to pull as well. :cry: Not to mention it engages faster due to the shorter span. He went from being terrified of this bike and unsure of himself, to rippin' up the field in a matter of minutes. Just by being able to reach the controls and having them more responsive. I would do this mod again no question. :cry::cry:
Does anyone still have the pictures posted on this thread. Can you email them to me? I need to make these adjustments for my daughter.
go to my garage.... they are there :)
