How to make 02 handle better
What do you recomend to make the 02 handle more like the 05? I heard sumone mention adjusting the clamps on the forks. If that works, how much do i slide it? Also what springs do you guys recomend.
Also what is a good long lasting set of tires, resonably priced.
thanks
1:send your forks to factory connection they will update your stuff to 05 specs.
2: get 03-04 linkage on ebay
3: get 22mm offset clamps on ebay
4: get piston, Cam, ignition for 04 on ebay
5: new plastic, graphics, pipe (BLING!)
Now you have an 04
Ok, where is the cheapest place to get the linkage? If anyone has a used one for sale, let em know. Also, i do mostly trail/offtrack riding. What is the best tire combo that really bites into the dirt. I find the stocks wash out way to easily and do not carve into the ground when i am turning. Ill try doing a search also. Thanks for the help
Now you have an 04
wrong! you need a lighter flywheel weight too :cry:
