shim job
trying to adjust valve clearance. rolled cams to the left without removing chain to expose valves cant seem to be able to get the cams back into place. is it easier to remove chain and cams completely or is there a trick to getting cams back in with the chain on?
you need to pull the cams to get to the shims. you do not need to remove the chain from the engine. you need to take off the cam chain tensioner, then take the cam covers off. then remove the cams from the chain. Search for the service manual on this forum because it syas exactly how to do this and has pictures to further guide you.
