JD jetting w/HT headers
I have a 2003 KTM 250EXC-RFS with HT headers and the Torque vane. I recently recieved my JD Jet kit, and I'm wondering if I go with what JD says or will I need different settings because of the headers and torque vane.
Thanks,
Jeremy
I would suggest running the standard setting. In some cases, a leaner carburetor needle clip position is used, but this should be close as written in the instructions.
---You may want to run the jetting without the Torque Vane but with header first to feel the change in response from the jetting kit. The kit is quick to install by just removing the seat and tank.
Thanks,
James
