Inner Rotor Ignition
I have a nephew racing a CRF50 and was wondering if the inner rotor ignition would kill the bike coming out of the corners. I want it to rev quicker but I didn't know if loosing all the inertia would kill it. He weighs whatever a 7yr old would so the bike doesn't have a huge load to get moving.
Also, what about the Ti clutch weights from Powroll???
Thanks,
Scott.
Its still stock 50cc's? The inner rotor would probably help it out and pull nicely. If you want to build the meanest 50cc stock bore 50, here is what you do.
Inner rotor
13:1 piston
Horstman Autoclutch
TB Stock head Race cam
xr70 carb and intake with head ported to match
Modded stock pipe,(So as to keep some backpressure, as the stock bore doesnt perform well with bigbore pipes)
And that should make for one of the fastest 50cc xr50's around.
Thanks but thats kinda pricey. Plus, I remember the Horstman stuff from when I was racing karts. Not worth the $ IMO. That has been a few years ago though.
Yea, it is pricey, I did ride one and the way it lets the bike rev is pretty amazing. The Ti clutch weights, and have the primary gear lightened will probably be good enough for what your looking for though. Lol, building it with the stuff I mentioned though, wow what a 50cc racer thatd be lol.
I'm happy with my inner rotor kit. Worked well when the bike was bone stock. It would pull on all the other stockers I ran against at the time. Works very well with a 75 kit. My bike will pull better on low end than an 88 kit with a carb and cam. They catch me on the straights but on a tight track it does very well.
  • Similar Content
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
    • By Wayno50
      Nostalgically bought this bike because it’s same model/year/size of what I had as a kid in the early 90s. I should have looked closer but was blind to its issues. Kid before removed tailpipe and put on a silly silencer which I just threw in the trash. Thankfully he kept track of OEM tail pipe but cut the end off of it.. I can only guess to make it louder. I have pipe back on bike but back pressure not good and sound not as tight as it should be. Does this need packing? Can I get a retrofit tip for the jagged 3” end?
