JD your thoughts on the WB carbon Pro jetting?
SO I get this sexy new Carbon pro and put it on my bike (2005 CRF450). It comes with a WB "Powerfilter" air filter and a 158 MJ. Instructions say to drop the clip 2 positions(raising the needle) and install the 158 (stock MJ is a 168). This tells me that they are saying the carbon pro will be RICH on the MJ and lean in the midrange-right? I have several friends with 04 250 & 450's that said that jetting won't work at all and to run stock jetting. So I did. I ran it for 20 minutes hard moto and checked the plug. WAAYYYY LEAN.....white with aluminum specs. I see a pro at the track with one and we talk. He says drop the clip 1 position and that he is running a 162- saying your rarely on the main jet (full throttle). I drop the clip one and leave the 168 main in. Ride some more. Still WAAAYYY lean. Drop the clip again- and rode the rest of the day. I did not check the plug yet but now the mid to full throttle pulls noticably harder. I pulled a holeshot ( I have video proof!) so friggin Huge against a gate full of intermediates and experts it was like they were all on 50's. I am anxious to see what the plug looks like. But as lean as it has been, I cant see dropping the MJ all the way to 158. Anyone have any thoughts????????????
Are you now using clip position #5 counted from the top?
Try turning the fuel screw outwards or run a #45 pilot jet if the bike is lean. I would not lower the main jet more than 2 steps from stock near sea level.
James
The clip is two positions lower thatn the stock setting ( I believe that there is only one more notch below it but I can't be sure-I do know it is two down from stock for sure) I still havent checked the plug since riding it in this position, but as I said, it ran noticably better at this setting. I am still using the stock 168 MJ. What on earth is WB thinking reccomending a 158-10 steps leaner than stock
I too have a 2005 450 and just got a WB Alum Pro with the same instructions to change to the supplied 158 main and 6th position. It didn't make sense to me either, so I came here and saw your post. Like to hear further tech help. Thanks! Mike Okano
Just received the 05 carbon pro for my 2005 crf 450 and read the instructions and it says for sea level that they recommend the stock jetting.
