15 T counter sprocket ?
Does anyone run a 15? I think that the case saver will have to be ground down a little. Where are they avaliable? Thanks , Geno
I removed my 14 and installed a 13 for a while, but then switched back to the 14. When reinstalling the 14, it was so tight, I wondered if I had the right sprocket. A 15 may fit, but based on my experience installing the 14, I think it would require significant case saver removal. You'd get pretty equal gearing by going to a 50 or 51 rear sprocket, but that may require a chain length change.
