Two Stroke Compression
When is it time for a piston kit for my son's YZ125? There seems to be very little compression when you kick it over. In fact, I can push the kick start easily with my hand. The bike still seems to have plenty of power. Your thoughts would be appreciated! :cry:
If power feels ok I would not worry about it (that much).
Have you done a compression test?
Do you hear the piston making noise? (piston slap)
Unless your Superman, you should not be able to crank a 125 by hand. Get an inexpensive compression tester at Autozone, and see how much compression the cylinder has and post back the numbers.
how many hours are on this top end?
how easy does it start?
powerwise, how does it run?
does it smoke a lot?
if you can push it over with your hand, then i'd say its time for a fresh top end.
It starts with three or four kicks and seems to have good power. Bought the bike used and we probably have 50 hours on the engine ourselves. It does smoke a lot but I think I am running it rich.
Haven't done a compreesion test yet and no, I do not hear piston slap.
Pull the carb and reed cage out. you can then look at the skirt on the piston and see how scuffed it is and sometimes starting to crack at the bottom and work it's way up. You can also see in the cylinder and see if there is any gouging or cross-hatching left.
I would change that piston asap. You shouldn't be able to push it through the stroke that easily. I remember a similar situation I had with a used CR 250. The bike felt pretty strong, but I just knew it had alot of hours on it when I bought it. When I pulled the piston there was a 2-inch hairline crack running right up the middle of the piston skirt. A couple more rides, and I would have chunked the motor.
I can start my 125 with my HAND when it's warm - new top end :cry: You have to remember, it's a two stroke AND it's only a 125... Run it until something goes wrong! I guess you could always just do a rebuild for the heck of it...
Well, its compression is 60 lbs. consistently. I think it is time for new rings!!
The proper way to figure out if it's time for a new topend is to measure the piston. It's the only way.
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
    • By MANIAC998
      This continues to be my favorite trail/race weapon!! In our Eastern tight woods, power is not King, handling is. And this thing outhandles them all!!!!
