Wr250f : Can/usa?
I hear that there is some difference between Canadian and US WR250F :cry: , is that true? If yes than what's the difference?
thank you
Cedric
The grey wire tells the CDI that it's in a WR instead of a YZ and retards the timing by something like 30 degrees above 6000 rpm.
It has been reported that '05 Canadian WR's have been "Californicated" and now have the longer throttle stop screw and grey wire.
The pipe has been changed for '05 and it is now a nice aluminum pipe, but with a smaller outlet (when unplugged). The good part is when you remove the restrictor, it is still below 96db.
