Exhaust valve leaking
Tore my 250f down for next season, doing a new piston, timing chain, etc... I did the contact cleaner test and one of the exhaust valves is leaking. I have had to do two adjustments on the valves (Over two seasons) , each time they were slightly tight. I have thought about replacing all the valves but money is def. a factor.
Bike was running great when I took it apart., and the valves were still in spec.
Should I try to clean the bad valve and seat, or maybe lapp it and see if it will seal?
I would perfer to replace the valves in a few months when my seasonal bussiness is actually making money...
If I do a total valve job what should I get,
Valves, springs, retainers, and what else??
Do it now or later?????
