What's the stock '04 450 offset?
Somebody has 22 mm offset triple clamps on ebay for $359. Is this a 2mm offset from stock or is it stock? I seem to recall the stock offset might be 24mm? Any Help?
You can get White Brother's 20mm here at TT for $242. They use your stock bar holders and steering stem (dealer pressed mine for $10). I rigged up a bracket out of an 'L' brace ($.49) to fit my '04 numberplate to the older style mount on the triple clamps or you can use an older plate. This way you can also use the stock bars until you bend them and then change to fat bars if you want later. Fastway sells metal cones if you want to go solid mount. I believe the '05 has different stop placment but I've heard people say they just file 1mm off the stops. Finally a cycra cable guide is $4.95. I know it sounds like a lot of jerry rigging and monking on a new clamp but it really wasn't a big deal. All done for $257.49.
Ph by the way, the best price I've seen for 24mm Applied clamps are from gopartsdirect.com for $246.95
