mx tech help!! subtank issue
my subtanks(mxtech-wilkey)were leaking oil at the air/oil valve on the top of the fork leg. twisted it with my hand using the subtank, and it broke off in the cap.. i need one of those male to male fittings. appears to be sae. can i find that at lowes hardware? ktm 450sx done in early 04 (mugans bike)
You should be able to take an easy out and remove it . It already has a hole in it to put the easy out in . Install a ew end ,use some teflon tape or pipe sealer to get it to stop leaking the oil.
Look in the Yellow pages for "hose". I found a local place that specializes in all type of hose. They sell the fittings. I believe they are intended to be used for hydralic lines. I believe I paid about 1.00 per fitting.
If you have any trouble finding them, give Jeremy a call, I know he has these on the shelf.
Take Care, John
