03 WR 450 Bogging
My bro just bought a 03 WR450. When we rode it I noticed a bog if you stabbed the throttle from a roll. I was in 5th, let off and slowed down a bit then hit it full throttle. It bogged then took off. I did the same in 4th and 3rd with the same results. If you keep the RPMs up to a fast idle it's fine but from a rolling idle it will bog. Even when it's parked at a idle and you rev it, it will kill the engine. The guy he got it from had a Yamaha dealer set up the carb like a YZ (doesn't that just mean you moved the needles or does the YZ have a different jets and needle?) uncorked the WR pipe, disconnected the gray wire, and removed the snorkle. Where should we start looking to fix it??
696
The YZ had a different needle.
What are the pilot, fuel screw setting, needle code stamp, clip position, and main jet?
The main jet may be too small if it's close to stock.
I'll post them later today when we get into it.
696
I think we got it. LEAN!!! on the pilot and a little rich on top. Run pretty good now :cry: . I'll be back if there is any more problems.
696
