Are the two compatable?
When it comes to sprockets are the E and S interchangeable? Of course, the teeth are different. My question is, can I order "e" sprockets for my s?
Thanks,
Dan
Thanks,
Dan
YES :cry:
don't forget to use the 100% pure conversion oil!............kidding
I think the only major bolt on difference is the exhaust pipe. You need to order S specific if going after market. Other then that ofcourse the s has the extended sub frame/s stuff. Wheels, bolts, are the same... in 2000/2001 they didn't give us S guys the good suspenion compoents but thats a whole other story.
Hey Gyro! Do you recommend a full conversion oil or just a conversion blend? :cry: Thanks guys for the info! I figured the 2 bikes would match up pretty good.
Dan
You can easily make an aftermarket E exhaust pipe fit an S, you just loose a peg (passenger not rider's :cry: )
well and you need an adapter to make it snug up all nice and tight. But that can be made pretty easy.
OH and while were talking about interchangable things.
A 2004 RM 125 front fender is exchangable onto your drz. Neat eh? Its a pretty fender too. The mounting holes are the same exactly.
i am wondering if he should use fully synthetic conversion oil or will mineral be ok :cry:
Ugh... Okay people its obvious.
Fully sythetic if you worry more about the shape of your engine then the shape of your belly.
Mineral if you are a health nut.
Pam if you are in a pinch and the store are closed. The woman of the house should have some around somewhere.
You don't have to loose the peg. I didn't anyway. I made a clamp to press the pipe mount against the subframe using a bolt through the original hole. Easy and works great....and my 6 year old son still gets to have a ride. :cry:
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
