Need Settings For '05 Crf250x Please!
I live in Missouri, which I don't think is much above sea level. I have cut the pink wire, cut out the top of the airbox, removed the air filter screen (should I have done this? Any benefit?), and have a rekluse auto clutch (if that makes any difference). I just bought the JD jetting kit. I checked the threads and guys are all over the place on settings. I don't want to do this twice. I already put the red needle in with the clip in the 5th position. Which pilot and main should I use and should I change the leak jet?
JIM
The stock #40 pilot jet will have the fuel screw turned out to near 2 1/2 turns. You may want a #42PJ if you want the fuel screw closer to 1 1/2 - 2 turns.
A #160 main jet should be a very good setting with the modifications you have made.
The leak jet is optional and not as noticeable as the other changes.
Thanks,
James
